Abnormal Nozzle Error
Just finished putting together my Ender V3 KE and started going through the set up and testing. When it begins the system test I receive a 2022 error / Abnormal Nozzle. Ive searched the internet but cannot find anything that explains this. Has anyone experienced this before?
Thank you.
Only thing I can think to do is unplug the ribbon cable on the print head and inspect the pins, I’ve seen posts where people have bent them over causing errors, though not this specifically, then reseat the ribbon making sure the clips go fully home. You also check that the 2 sets of wires from the hotend aren’t damaged and that the connectors are properly seated, just because they are glued doesn’t mean they are seated. Beyond that I don’t know.
