About the k2
I got the k2 and I was big and worked but after a few months I started to have to replace many part on it, most of its parts are about 20$ so about each month I had this printer I had to spend 20$ a month I spend about 150-200$ ons parts for it. I wish I could return it but I can’t.
if you have the printer only for a few months, it’s covered under warranty, why would you be purchasing parts? Make sure to contact creality customer support if you’re having issues, so that they can troubleshoot and understand what is wrong with it, and if there is indeed any part that has manufacturing issues that should be replace under warranty
I have one for you, K2 Combo, I replaced the hot end, extruder and cutter. now if I try to calibrate it says “filiment detected in extruder, if I try to print it says “cutter is missing or jammed” if I try to load or unload it says the same. I talked to creality yesterday and no answer, waiting for the expert toemail me back 24 to 72 hours. any help?
