Auto mesh calibration with Orca
After switching over to Orca slicer every time I send a print to the Hi it does a print calibration. In Creality Print you can disable this but not so Orca. Does anyone have a solution?
Can you share the g-code start? It should be over there
The Machine start G-code
M140 S0
M104 S0
START_PRINT EXTRUDER_TEMP=[nozzle_temperature_initial_layer] BED_TEMP=[bed_temperature_initial_layer_single]
T[initial_no_support_extruder]
M109 S[nozzle_temperature_initial_layer]
M204 S2000
G1 Z3 F600
The Orca Start print G-Code
As you will see I have already commented out the Bed Mesh
[gcode_macro NOZCLEAR_START_PRINT]
gcode:
G92 E0
G1 Z3 F600
M83
G1 Y100 F12000
G1 X-2 F12000
G1 Z0.28 F600
G1 X-2 Y100 F4000
G1 X-2 Y-2 E15 F2000
G1 X60 Y-2 E9 F2000
M82
G92 E0
[gcode_macro END_PRINT]
gcode:
ENABLE_PRESSURE_ADVANCE VALUE=1
{action_respond_info(“END_PRINT trigger ENABLE_PRESSURE_ADVANCE=1”)}
{% set act_z = printer.toolhead.position.z|float %}
{% if act_z + 50 > 305 %}
{% set pos_z = 305 %}
{% else %}
{% set pos_z = printer.toolhead.position.z|float + 50 %}
{% endif %}
G1 F3000 Z{pos_z}
BOX_END
BOX_END_PRINT
G1 F3000 X0 Y260
M104 S0
M140 S0
M107
M84
[gcode_macro START_PRINT]
variable_prepare: 0
gcode:
Rmode_exit
BOX_ERROR_CLEAR
BOX_START_PRINT
{% set acc = printer[“gcode_macro PRINTER_PARAM”].default_acc %}
G90
SET_GCODE_OFFSET Z=-0.025
SET_VELOCITY_LIMIT SQUARE_CORNER_VELOCITY=10
M204 S{acc}
SET_VELOCITY_LIMIT ACCEL_TO_DECEL=8000
{% set g28_extruder_temp = printer.custom_macro.g28_ext_temp %}
{% set bed_temp = printer.custom_macro.default_bed_temp %}
{% set extruder_temp = printer.custom_macro.default_extruder_temp %}
{% set BED_TEMP = params.BED_TEMP|default(45)|float %}
{% set EXTRUDER_TEMP = params.EXTRUDER_TEMP|default(200)|float %}
{% set EXTRUDER_WAITTEMP = (EXTRUDER_TEMP/1.5|float)|int %}
# {% set y_park = printer.toolhead.axis_maximum.y/2 %}
{% if printer[‘gcode_macro START_PRINT’].prepare|int == 0 %} #fuildd网页打印
{action_respond_info("print prepared 111")}
M106 S0  *#需要关闭模型风扇*
M140 S{params.BED_TEMP}
M104 S{EXTRUDER_WAITTEMP}
G28 X Y
NOZ_CLEAR
ZDOWN_SWITCH ENABLE=1
G28 Z
BOX_GO_TO_EXTRUDE_POS*#M1500*
M190 S{params.BED_TEMP}
*# BOX_NOZZLE_CLEAN#M1501*
; Z_TILT_ADJUST
*# BOX_GO_TO_EXTRUDE_POS#M1500*
ZDOWN_SWITCH ENABLE=0
*#M190 S{params.BED_TEMP}*
SET_PIN PIN=fan0 VALUE=127
M109 S45
M106 S0
NEXT_HOMEZ_NACCU
G28 Z
*#BED_MESH_CALIBRATE*
*#CXSAVE_CONFIG*
{% else %} #其他打印
{action_respond_info("print prepared 222")}
PRINT_PREPARE_CLEAR
{% endif %}
G0 X0 Y0 Z3 F12000
M104 S{params.EXTRUDER_TEMP}
# G1 Z5 F600
M109 S{params.EXTRUDER_TEMP} ;wait nozzle heating
M220 S100 ;Reset Feedrate
M221 S100 ;Reset Flowrate
G21
G92 E0 ; Reset Extruder
