Read further if interested, but I solved my PC connection to the touch screen problem that was prohibiting me from re-imaging it back to stock and therefore unbrick it…the solution was finding out that text in the unbrick info used the term USB-C instead of meaning USB-microC connection. There is both “under the hood” of the touch screen and a video I found online showed the correct connection point and I grabbed a data USB-microC cable and re-followed the instructions and my KE is back to stock.
Help/advice needed. KE worked great except their app and video in Creality Print was becoming unusable so I Rooted and used Fluidd/Mainsail and even installed Guppy screen but changed back without issue and worked great until today when I reinstalled Guppy screen.
FIrst the Creality Logo would not go away on the touch screen but after a restart and waiting for a couple minutes the printer booted up with the Guppy screen working.
However I decided I needed to wait until I got an extension cable delivered and print a rotated screen adapter block so I went back in to Putty Menu and Removed Guppy. I reinstalled a couple other settings (that worked previously) and this is when all hell broke loose.
First off, the printer would not complete a restart to the normal screen. Then I tried to connect via Putty helper load screen and my PC couldn’t find the printer.
I figured it bricked itself so I followed the unBrick instructions and downloaded the files, but I can’t even get past Windows 10 showing "Unknown USB Device - device descriptor request failed).
I did try to make sure Cloner Win32 Driver was installed (only way was to click on usb_cloner_device_inf) but Windows 10 refuses to acknowledge that an authorized device is attached. I even went so far as to edit the Windows settings to ignore device signing and reboot the PC, to no avail.
I simply cannot get Windows to connect to the Touch Screen headunit and therefor cannot unbrick it. FIgures that POS Windows is going to screw me over unless somebody has an idea???
Thanks for input.
