CA2711: Auto Belt Tension Failure.
After printing with the Creality K2 Plus for about a week, I get a clog followed the procedure to unclog the machine. And now i get this error message along with some noises through the x and y. Apart from this odd issue the printer has been a good experience. Does anyone else have odd noises?
After looking around I came across something that seems to work. It was in Palace’s thread where Optimus shared a Wiki thread labeled “Handling Closed-Loop Motor Faults: Recalibrating the Motor Zero Position in Fluidd”. Now the noises from my original post are gone. However, i still get the same error code. Currently I am doing a Benchy test print to see how things turn out.
Also, i am not sure how to access the Fluidd page that is mentioned in the wiki. How do i access this? Is there a how to guide for the k2 plus?
for Fluidd open your web browser type in the IP address of YOUR K2 followed by :4408
if the IP of the k2 is 192.168.1.100 it should look like 192.168.1.100:4408
you can also watch the camera stream in your web browser with adding :8000 to the IP
Thank you AnHe! That worked. Also, looks like whenever the auto belt tensioner acts up so far the solution has been to recalibrate it with the provided gcode and rerun the calibration sequence. I had the same issue a couple more times. Hopefully everyone else has better luck than I do. Especially with jams.
