I am trying to get the picture in lightburn to indicate the position on the material in the laser When I do a frame procedure it is off by a significant amount. Also do you set the camera to fisheye when calbrating the camera?
thank in advance
thank in advance
Have you adjusted for the height of the material compared to where you calibrated it (parallax effect).
Not sure which Falcon you have exactly. You can use standard camera type.
