CFS filament buffer bowden tube length
When connecting the Bowden Tube from the extruder to the filament buffer, how far into the buffer should it go? Should it just go to the top of the buffer and does it go down in the buffer to the clamp on the moving part?
You can manually rise the side tab of the hub until tops to the upper ring, now you can push the tube 2 or 3 mm until it stop, so no need to worry for alignment. you do not need to make any force simply push.
Thanks, I wasn’t sure how far down it went. This clears it up.
