did you get the part and did if fix the problem?
I own a K2 Plus combo. There are so many complaints about the CFS that I decided not to use it after a successful multicolor benchy, which took so long and produced so much waste. Anyway, 99% of my prints are functional ones, which have no use for multicolor. Right now, my CFS is unplugged and used as a box to protect my PETG filaments from humidity.
Yes I did. I replaced the motor sensor assembly and it worked fine. Most items are available easily now on Amazon
My CFS has been doing the same thing since it was new. Weak Feed Motor . Now its causing errors. The motor is not powerful enough to Feed the filament or Retract the Filament. It struggles to do the simplest of tasks. Under Engineered from China.
Hi, another victim of the issue here, ive replaced the motor unit at the bottom of the CFS and am still having the same problem. Ive reached out to Creality but its been about 2 weeks and the problem is still with their engineering team. Has anyone found a solution to this yet? @cmoore My issue also developed after a long string of ASA prints so im curious if the high temp is what caused it… Ive been a dedicated Creality user for a long time and this issue actually drove me to try out Bambu products and while its stil early im very impressed with my P1S printer and thinking of trading out all my creality printers for Bambu….
