hi!
i think i founded some bug…
system:
creality print 6.2 win10
creality hi (1.1.0.48)
cfs1(1.1.3)
cfs2(1.1.3)
cfs3(1.1.3)
(cfs - edit - creality - pla - crpla 190° - 240° pressure advance 0.04mm) - selected for all 3 cfs
problem1:
can’t select other temps, except 190-240
problem2:
can’t select other pressure, except 0.04mm
problem 3:
when i select in slicer temp for the first layer 220
and for other layer select 210,
system for first layer use temp 220 & for other layer use temp 210, but
after next filament changing system use temp 220 for all other layers, even i selected in slicer another filament with settings 210 for first and 210 for others layers
i need 220 at start and 210 for all others layers, how can i solve this?
problem4:
when system changing next color (pla), nozzle temp is 240, can it change color al lower temp?
how can i select another temp in cfs edit menu?
thank You for Your work:+1:![]()
