Changing filament mid-print on Ender-3 V2
When my print pauses (as directed in gcode) the “tuning" menu does not show any option for filament change or retract or extrude. How should I proceed?
Hi. If your printer is an original ender 3v2 running marlin firmware. I you use M600 inserted in the gcode to do filament changes. You may have to do this manually with a gcode editor - notepad++ at the layer change maker. If you are using octoprint you can manually insert m600 at the command line at the point you wish to change filament.
N600 will park the print head off to the side then extract 300mm filament. Remove the old filament then insert new filament into the extruder then press load on the screen. the extruder will load 300mm of filament then run a purge cycle. If filament is not extruded during the purge cycle select purge more until filament is extruded. remove excess filament then press continue to resume printing.
Bill
