Coprint KCM Set
Le_zOU1 says it right, you don’t have to do anything with any cfg, you just have to put the coprint firmware on the printer. I’ve since upgraded to the 8-color version, and I didn’t have to do anything, just turn on the remaining 4 extruders. It works flawlessly. However, the filaments… some break like crazy.
So, I have fixed a lot of the problems that I was having, but a big one still remains. When I send a print from Orca to my Ender 3V3 plus with the CoPrint 8 color, the CX-I extruders retract all filaments (individually of course), and then tells me there’s a clog. I have disassembled the hot end, cleaned thoroughly, removed all filament from the 8in1 module, confirmed that all lines are clean and clear. Just weird since I have never had a print on this damn thing.
Has anyone else had the “extruders retract when needing to extrude” issue before? If so, how did you fix it? I’m losing my mind over here…
Filament sensor stuck and believes there’s still filament ? \=> Coprint KCM Set - #41 by Le_zOU
