CR Touch Auto Leveling Sensor
Did I understand it right, the CR Touch Auto Leveling Sensor
will automatic rise the extruder to the right level if I put a glassplate on the bed, its 2,5 mm thicker than the plate I have now.
I don´t have to adjust anything manually?
The CR touch should work with the glass buildplate but I don’t know about the strain sensor in the bottom left corner.
I’ve just changed mine to a glass plate and CR Touch works perfectly. It really was as simple as ‘plug and play.’
Not sure if I like the glass bed but yes, CR Touch works well.
Sounds great! Thanks!
