Creality K2 Plus – Multiple Failures, Nonfunctional Filament Cutter, Error Codes, and Serious Reliability Concerns
I’m posting here because I need some actual answers regarding the ongoing problems with my Creality K2 Plus. This machine is used in my small manufacturing business, and these problems are interfering with production and customer orders.
I upgraded from a K1C, which was an extremely reliable machine for me. Frankly, my K1C was running circles around this K2 Plus in terms of reliability, and that’s becoming incredibly frustrating considering what I paid for the upgrade.
Here are the problems I’m currently dealing with:
  1. Filament cutter completely nonfunctional. The cutter mechanism does not work. Period. During the initial failure, I heard a very loud clunk when the printhead apparently struck the cutter actuator (hammer mechanism). The machine stopped, and the print bed lowered to the bottom.
  2. Recurring error codes. I’ve encountered both “Coordinate Overrun” and “CM2789-y.” These errors have appeared during the machine’s checks and calibration procedures.
  3. Cutter calibration failure. The machine has exhibited abnormal diagonal movement during cutter-related calibration and fails to complete the process correctly.
  4. TPU extrusion problems. TPU-95A has been considerably more troublesome on this machine than it ever was on my K1C. On one occasion, the TPU actually wrapped around the extruder gear, requiring me to completely disassemble the extruder to remove it. This is unacceptable for a machine I’m relying on for production.
  5. Firmware concerns. These major failures began after updating to firmware 1.1.7.0. I’ve since rolled back to 1.1.4.11, but the problems have not been resolved.
  6. Reliability and workflow problems. I’ve also experienced intermittent network communication issues with OrcaSlicer, adding to the frustration of operating this machine.
What I’ve already done and verified:
  • Replaced the extruder.
  • Rolled back the firmware from 1.1.7.0 to 1.1.4.11.
  • Successfully performed bed leveling, belt checks, and input-shaping calibration.
  • Confirmed the printhead cover is firmly secured.
  • Inspected the filament cutter blade and confirmed it is in good condition and properly installed. The blade is not damaged, loose, or incorrectly positioned. I have not modified or tampered with the blade assembly. Please do not suggest checking or reinstalling the blade. It has already been verified.
  • Verified that the machine can still print and retract filament normally.
  • Continued changing filament manually because the cutter mechanism is inoperative.
The printer has approximately 168 hours of printing time. A machine with this little use should not be experiencing this level of mechanical and operational trouble.
What I’m looking for:
I need someone from Creality, or someone who has experienced these exact problems, to explain what is actually failing and what the proper resolution is.
I’m not interested in repeatedly being told to check the printhead cover, inspect the cutter blade, run the same calibrations, adjust belts, or disassemble the machine without a clear diagnosis. I’ve already spent considerable time troubleshooting a machine that should be working.
If this is a firmware issue, I want to know whether Creality has identified it and developed a fix. If it’s a defective cutter mechanism, toolhead assembly, or another hardware component, I want the appropriate replacement or warranty resolution.
This printer is not a hobby or a toy for me. It’s manufacturing equipment for my business.
I purchased the K2 Plus expecting an improvement over my K1C, particularly in performance, capabilities, and reliability. Instead, I’ve spent more time diagnosing problems than I ever did with the K1C.
I’m not asking for miracles. I’m asking for a printer that operates as advertised, and for Creality to provide a definitive solution rather than sending me through the same troubleshooting procedures repeatedly.
Has anyone experienced this combination of Coordinate Overrun, CM2789-y, and complete filament cutter failure? More importantly, what actually fixed it?
I’d especially appreciate a direct response from Creality technical support regarding whether this machine needs replacement hardware or a warranty replacement.
One final thing regarding technical support:
I would genuinely appreciate the opportunity to speak directly with someone who can verbally walk me through diagnosing and resolving these problems. I’m much better at working through mechanical and technical issues when someone can explain things to me in a conversation rather than sending me lengthy written instructions.
Every 3D printer I’ve owned, particularly my K1C, has essentially been a plug-and-play experience. I didn’t have to constantly adjust the bed, troubleshoot mechanical components, or spend hours tinkering with the machine. I plugged it in, dialed in my filament profiles, and went to work. That’s exactly what I expect from a printer.
When I upgraded to the K2 Plus, I transferred my established filament profiles and made the necessary adjustments for the new machine. Everything was working reasonably well until the firmware update. Since then, it seems like one problem after another has developed.
I’m now having to perform filament changes manually, much like I did with my K1C. That was perfectly acceptable on the K1C because that’s how the machine was designed to operate. However, the K2 Plus has an automatic filament-cutting mechanism, and I expect that feature to work. It eliminates an unnecessary step in my production workflow.
I also recognize that many people in the 3D printing community genuinely enjoy tinkering with their machines, modifying components, and experimenting with settings. That’s perfectly fine, but that’s not why I purchased this printer.
I’m not in the business of making toys or spending my free time experimenting with 3D printers. I manufacture specialized products for professional musicians through my company, The Overall Mute Company. My printers are production equipment, and I depend on them to help me earn a living.
Every hour I spend troubleshooting a machine instead of manufacturing products is time taken away from my business and my customers.
I need a reliable machine, a clear diagnosis, and preferably someone from Creality who is willing to speak with me directly and walk me through an actual solution.
I don’t believe that’s an unreasonable expectation for equipment that is supposed to be an upgrade over what I was already using.
Let’s start with the cuttingissue. On the left side there should be a finger that triggers the cutter. Please check it isn’t broken.
As your cutter isn’t working at all, this is the most likely cause.
The overrun error does that happen when moving to the left? When trying to cut the filament?
I did a check for you if you need a new cutter push rod.
SUBJECT: Urgent Technical Assistance: K2 Plus Critical Multi-Motor Failure (CD81 / CM2789) & Factory Reset Loop After Firmware Issue
Dear Creality Technical Support / Community,
I am writing to report a critical, cascading hardware/software failure on my Creality K2 Plus that has left the machine completely nonfunctional. The printer turns on normally and allows menu navigation, but it is currently trapped in the initial factory calibration sequence. The exact second it tries to initiate any movement or physical self-check, the printer freezes instantly and triggers a massive multi-motor panic shutdown.
:police_car_light: Current Error Codes displayed on screen:
  • K2Plus-CD81: General system panic code.
  • CM2789 (Multiple instances): Abnormal resistance detected in the direction of movement — X motor released, Y motor released, Z1/Z2 bed motors released, and Extrusor (E) motor released.
:hourglass_not_done: Chronological Overview & Symptoms:
  1. Initial Failure: The machine started showing intermittent strain gauge errors on the left tensioning module (CA-series errors, such as CA2715). Shortly after, the right X-axis motor suffered a permanent internal failure, exhibiting massive physical resistance when turned by hand outside the machine.
  2. The Trigger: Following this, after attempting to clear the system state and performing a Factory Reset, the machine entered the “Out of Box” wizard loop.
  3. The Current State: The mainboard boots fine, but as soon as the initial setup prompts the printer to calibrate the filament cutter or check the axes, the system tries to draw power/move, experiences an immediate fault, and throws the CD81 and CM2789 errors across every single closed-loop motor simultaneously.
:hammer_and_wrench: Hardware Diagnostics and Solved/Verified Steps:
To save time and bypass the standard generic troubleshooting steps, I have already performed and verified the following comprehensive diagnostic procedures:
  • CoreXY Mechanics: Clean and smooth. With the printer completely powered off, the toolhead and gantry slide manually across the rails with absolute freedom and zero friction. There are no belt overlaps or mechanical jams.
  • X-Axis Motor (Solved): The failing right stepper was removed and completely replaced with a brand-new original Creality spare motor. It now spins flawlessly.
  • Toolhead Cable (Solved): A brand-new original Toolhead Cable was routed and installed perfectly. Testing with both the old and new cables yields the exact same cascading error pattern, completely ruling out a toolhead wiring break.
  • Tensioning Modules Swapped (Verified): To isolate the original left-side error (CA2715), I physically swapped the left and right tensioning motors alongside their strain gauges. The error did NOT move to the right side; it remained firmly locked on the left. This definitively proves that the tensioning hardware and sensors themselves are 100% healthy.
  • Fuses Inspected: The back panel was removed to inspect the mainboard (Lower Computer Mainboard). The board looks pristine, and no visible damage or blown components are apparent at first glance.
:clipboard: What I Need From Creality Support:
Given that this exact cascade of CM2789 across all closed-loop drivers (X, Y, Z, E) during cutter/axis calibration is an ongoing issue reported by other K2 Plus owners in the community after recent firmware iterations, I need a definitive diagnosis:
  1. Mainboard vs. Power Supply: Since the errors explode the exact second the drivers try to energize for movement, does this sequence indicate a blown power rail/SMD fuse on the mainboard, or a failure in the 48V power supply line?
  2. Specific Parts to Purchase: As this machine is out of warranty, please tell me exactly which replacement part I need to buy to skip this firmware/power freeze loop (e.g., Mainboard, Extruder Board, or PSU).
I am looking forward to a direct, concrete response from a level-2 technical engineer. Thank you for your urgent attention to this matter.
Best regards,
