Creality Print 6 just broke my V3 Plus
Switched to CP6 today, and printed a few things, then, went to print, it sent it, and CP6 moved to the ‘device’ screen like normal where it shows the stats, but nothing started printing, the stats show the printer just sitting idle.
From the touch screen on the printer, if you go to files, it just shows a page of blank files, that say ‘text’ and the error cudir has no files.
I’ve turned the printer off and on, and restarted CP6 to no change.
The printer now shows a yellow symbol next to the now dark wifi symbol, i don’t know what that is.
as well, when i went to settings and pressed the motor unlock button, it does nothing. and when i hit the home printer button, the printer went to the limits but then freezes on the screen saying ‘homing please wait’
Can you access your printer in web browser using the IP address and add :4408 to the end to use the Fluidd interface. You should be able to delete the stored gcode files from there, power off and back on to see if it is fixed
