Creality print 6
is anyone else having problems with creality print 6 or am i the only one in the world.
when i slice a model i get an error saying that the model has floating regions?
Hi there,
You are getting this message because an upper part of your model over hangs a part that touches your bed plate, meaning one of your layers isn’t supported. If you add supports to the model this will then go away because the floating part of the model will be supported. If you were printing a square box for example every layer would be supported and you wouldn’t get that message.
The3DPrinter7693
