I can’t print via the internet using the Creality Print app. There’s no problem at all when printing locally. I can also print via the internet using my iPhone and iPad. The problem is only when accessing the printer via the internet using the Creality Print app on my computer. When I open the app, I can see the printer and the camera is working, but I can’t send the file to the printer.
I set up the whole system from scratch. I reserved the printer’s IP address on the modem etc. but didnt worked
Are you using a laptop to access the app?
Yes , but I tried other ntbk but result it same.
i have the exact same problem, cant figure it out, it says its connected, but only load 1% and then fails to dowload to printer. i have to use usb meanwhile when im troubleshooting
How do you use a usb drive for remote access?
J’ai exactement le même problème!
