Csf lite with the sparkx i7
Having problems with hole number 2 in my csf lite it’s not taking filament it was then just stopped
Hello, the issue is most likely with the filament feed mechanism. You should take it apart and check—it’s possible that some filament has gotten stuck somewhere. If the drive mechanism isn’t working because it’s broken, please contact technical support, and they will send you a replacement part.
