Hey everyone,
I’m brand new to 3D printing, and I just got my Ender 3 V3 KE on Sunday. Everything was working perfectly up until midday today. No settings or hardware changes, but suddenly, my print status and temperature readings stop updating once the printer starts printing.
What’s Happening:
- When the printer is idle, everything works fine—temps show correctly, camera works, and I can monitor everything from the Nebula screen, Creality Print on my PC, and the mobile app.
- I send a file to print, and it starts successfully (no failed prints).
- As soon as the printer starts heating up, temperature readings freeze, and the print progress stops updating on Nebula, the PC, and the app.
- The print still inishes successfully, but I have no way of tracking the status or time remaining.
- The camera works throughout the print, so the PC is still connected—it’s just the temp and progress that drop.
What I’ve Tried So Far:
- Factory reset the printer through Nebula pad.
- Rolled back the printer’s firmware to the original version (1.1.0.14).
- Updated the firmware back to the latest version (1.1.0.15).
- Reinstalled Creality Print (tried both v6.0 and v5.1) same results.
- Checked all cables and connections inside and out—everything is tight and secure.
- Sent a print via USB instead of WLAN (same issue).
- Tried a different WiFi network (still no change).
Symptom When Using USB:
- When printing from USB, Nebula repeatedly flashes a message saying a USB drive was inserted (every few seconds), but the print continues.
At this point, I’m at a loss. I can consitently recreate the issue but im at a loss for a resolution. Any ideas? Has anyone else run into this?
Thanks in advance!
