I had a blob this morning and when I heated the nozzle to 210 to remove I noticed the heat break fan wasn’t working, but when I checked the connection was still good. I took the heatbreak fan and connected it to the part cooling connector and the fan turned on and worked fine. I checked printer.cfg (running klipper) and checked that any temp over 60c will turn on the heat break fan. I plugged that part cooling fan into the heatbreak connector and it did not work. I looked at the very tiny pins and they seem not to be bent out of shape.
Any other ideas on what to fix or how to figure out what the problem is?
