Glad it helped. Like you said the pinout on the Ender 3 V3 board is different than the plug’s layout for the K1 fan. Good find on the back of the board
On my setup, I cut the plug off the original V3 fan and solder it to the K1 fan, yellow to yellow (signal), red to red (Vc), black to black (grd), green to green (pwm). I would recommend this to most to avoid any confusion.
In your case it sounds like you didnt have the original fan and used the K1 plug which is clever just a little color code confusing I guess if others did what you did, they could keep the original fan as a backup. I would have to solder again, and would probably buy another K1 fan b/c of the airflow upgrade.
Before cutting the wires i tried to pry out the pins from the K1 plug to rearrange them as well as desolder them from the fan but deciced cutting was easiest.
The K1 Fan is much stronger and a good upgrade. I did some quick overhang tests and did see improvements So you now have a better working machine then the original
I kmow this isnt the same connector as on the ender 3 v3 but itll give you a good idea. If you gently pry the plastick back right under where you see the metal the pin just slides out. You might have to hold it plastic back while pulling on the wire to get it just take your time and do 1 at a time. This way only took me about 5 min tops. Also im trying to upload a pic of the connector for reference again i know its slightly diffrent then what one the v3 but itll give you an idea. If it doesnt upload im sorry im new to forums
I just reconnected the wires in the connector itself, it’s not difficult, you just need a thin blade and a little patience) Everything worked without problems. But now I’m confused by the fact that I’ll probably have to redo all my printing profiles, because the wind is blowing much stronger now.
Fala galera do Brasil que tiver uma ender 3 v3 core xz e quer fazer esse upgrade, eu acabei de fazer ele, comprei o cooler no aliexpress, chegou certinho. Só que a ordem dos fios são trocadas então recomendo ir pela cor. Na minha impressora o cooler dela no conector de cima para baixo a ordem de cores é Amarelo, Vermelho, Preto e Verde. já na fan que veio, a ordem era Vermelho, Amarelo, Verde e Preto. só cortei os fios e emendei de acordo com a ordem do cooler de fábrica ao invés de cortar os fios do cooler e emendar no novo para manter ainda a integridade do cooler que vem de fábrica. Vou fazer alguns testes ainda e dou um veredito à respeito do upgrade!
i think the connector is a molex picoblade, i bought some and they seem to fit, not exactly sure, thats what my research shows me, for sure not the sh more GH except there is no side retention bracket
Also running Ender 3 Pro machines. both have the V4.2.7 motherboards . Will that extra draw on the double amps hurt that board? Also have the dual z axis installed . Both motors on the same circuit. U having any issues ???
