Good Morning,
I have an Ender 5 - Max that has been pretty consistent. I recently put an enclosure on and now I am getting Levelling Sensor Anomaly when attempting to level the unit.
Ive changed the strain gauges, the heatbed,
I reset to factory defaults and tried again and im still getting the error.
Any input would be appreciated
I recently got the ender 5 max and the enclosure. Having a major issues here. When i installed the side panels of the enclosure they warp inwards, so the screw holes in the frame on the top and the bottom are closer together (on the z-axis) than the screw holes in the side plates. This means the panels press onto sides of the bed, causing the z-axis movement not to move cleanly and therefore the bed tilts! - check this!
I don’t know how to fix this! - did i buy a faulty machine ? or can this somehow be adjusted?
Hey i managed to fix the bowing side panels of the enclosure, first i undid all the corner bolts, top and bottom, jiggled the machine, squared it up. Re-tightened them. Then the most important thing was, i had over tightened the top securing bolts for the 2 z-axis units on the two sides. This was pulling whole top part of the frame down and in, bowing the side panels in. As mentioned, the inward bowing side panels were causing the sides of the bed to scrape against the bowed side panels, causing issues with the bed leveling. It also sorted the gantry pulley wheels knocking against the central bolt housing that was causing a bump in my prints, as mentioned in another post.
Man what a complex machine. Still getting horrible resonance noises but at least its printing.
