Extruder issues
Recently, I have run into an issue with my Ender 5 Max. The extruder is not pulling the filament into the hotend.
I can hear the gears grinding the filament. I have already replaced the extruder because it was jammed with filament. Then I replaced the Bowden tube because it wasn’t allowing the filament to pass freely.
Has anyone else had this problem? How did you fix it?
Right now, I can’t figure out what else could be causing this issue.
Thank you
HP
