Extrusora
Minha extrusora não apaga a luz aparece o erro como se estivesse filamento dentro dela não consigo resolver
If you can not print, I think you are going to have take off the extruder and check for clogged filament.
remove the extruder and check for the sensor not clogged or a piece of filament on it. be careful with the cables.
Já fiz isso
So the sensor is not working fine, check the cable is seated on booth ends
