This is starting to drive me insane and costing me quite a bit of filament. Every 3rd time I auto refill the same color it fails, normally this isn’t a problem if I am around to hear the beeps. Yet if I happen to be sleeping 1 of 2 things will happen. 1) It will start printing in mid air. 2) It’ll stop printing and wait for me to intervene, yet it lets the plate cool down and looses adhesion.
Any Idea? Seriously this past week it’s caused 3kg of failed prints.
Just out of curiosity, what type of filament does it happen with? Which brand are you using?
It’s done it with both PETG and PLA. I don’t believe the filament is a problem I have 4 printers and let’s just say the other brand isn’t having this problem. Just the 2 I7’s I’m thinking the CFS Nano is causing the problem.
If you have the CFS nano, you might be right; I think there’s a motor with some electronics inside. Pay attention to whether it always jams on one of the 4 outputs, or only after a specific number of times, or after a direction reversal—for example, if the outputs are 1 2 3 4, whether it happens when going from 3 to 2 (changing from right to left) in the sequence 1, 3, 2 or from 3 to 4 (changing from left to right) in the sequence 4, 3, 4. It’s important to observe changing from 4 to 1 and viceversa.
Well i figured out what is going on, some of the spools of filament the end of it does not slip out of the spool easily, The Nano has to give it a good yank to break it loose and isn’t strong enough so it starts air printing. I’ll probably have to bend the filament so that it will slip out of the spool at the end easier… only took me 15 or so failed prints to actually be sitting here when it did it.
I am assuming the full CFS the motors are stronger and this isn’t a problem. Something to keep an eye on for all those K3 units that are going to ship.
