Falcon A1 does not load any files
Falcon A1 does not load any files,DXF, STL
Yes, unsurprisingly, this won’t work because the Falcon only loads GCODE files. If you want to process SVGs or DXF files, you have to use either LightBurn or Falcon Design Space and then stream them via USB to the Falcon, or if you want to use a file directly on the Falcon on a flash drive or memory card, you have to use the mentioned applications and export a GCODE file, which is a machine-processable file that the controller on the Falcon can execute. It does not work with the raw image files, but needs the instructions in the G-code file. Just like a 3D printer also doesn’t run on STL files but also needs G-code.
Thanks, but I use Falcon Design Space, and still it will not load and Falcon Design Space says , file parsing failed!
