Hi, I have a quick question or concern for my print that I am trying to complete.
It was going really well at the beginning but half way through it started to make this noise. And as i was taking a closer look at it, the filament has not been sticking to the previous layers that were laid. If you could help that would be awesome.
*And yes just to be safe the filament has been sitting in the dryer and the dryer has been running. There is plenty of filament to complete the print.
Is that grid infill? I would try something that doesn’t cross itself like gyroid.
The infill pattern was set to Default which is Monotonic. I did switch it to Rectilinear but didn’t feel like starting another print until I can have some time to keep an eye on it.
Looks like grid but also have you tuned your flowrate? Perhaps lower the flowrate by 10%
I have not messed with the flow rate. I could possibly slow down the print if you think that might help with resolving the issue.
I think it is a bit of both, if the flowrate is too high is binds up with too much material
Is there a video or article that tells me how to mess with the flow rate correctly so i don’t mess my printer up?
