[GUIDE] Creality K1 Max – Recovering an S12 Motherboard Running S11 Firmware (Ingenic Cloner → S12/X2000E)
I recently went through the process of recovering my Creality K1 Max with a CR4CU220812S12 motherboard after it had been flashed with firmware intended for the older S11 motherboard.
After quite a bit of troubleshooting, I managed to get it back onto the correct S12 firmware branch.
I’m posting the procedure that worked for me in case anyone else ends up in the same situation.
WARNING: This involves low-level firmware flashing using Ingenic USB Cloner. There is a risk of bricking the motherboard. This is not an official Creality recovery procedure, and I can’t guarantee it will work for every board.
The problem
My K1 Max physically has the following motherboard:
CR4CU220812S12
However, it was running:
CR4CU220812S11 – V2.3.5.34
The printer was functional, but it was on the wrong firmware branch.
Attempting to install the newer S12/X2000E firmware directly did not work. The older firmware’s OTA updater could not extract the newer image format correctly.
The solution was to roll back to an older S11 firmware, install an intermediate update, and then use a special bridge firmware to transition to the S12 branch.
Files required
These are the files I used, in installation order:
  1. CR4CU220812S11_1.3.3.5.ingenic
  2. CR4CU220812S11_ota_img_V1.3.3.46.img
  3. CR4CU220812S11_ota_img_V1.3.3.50.img
  4. CR4CU220812S12_ota_X2000E_V1.1.0.27.20260703.img
Software required:
  • Ingenic USB Cloner 2.5.18 for Windows
  • Ingenic USB recovery driver
  • Windows PC
  • USB data cable for the motherboard’s internal recovery USB connection
  • FAT32 USB drive for the normal firmware updates
Above mentioned files can be downloaded from my Google Drive:
Important: These instructions are specifically for a physical S12 motherboard incorrectly running S11 firmware. Don’t use them blindly on an actual S11 motherboard or another K1 Max motherboard revision.
Step 1 – Back up your existing configuration
If your printer is rooted and you still have SSH access, back up anything you want to keep.
I backed up my printer configuration, Helper Script, CFS Helper Script, and custom Klipper modifications.
For example:
BACKUP=/usr/data/helper-backup
mkdir -p "$BACKUP"
tar -czf "$BACKUP/printer_data_config.tar.gz" \
    -C /usr/data/printer_data config
[ -d /usr/data/helper-script ] && \
tar -czf "$BACKUP/helper-script.tar.gz" \
    -C /usr/data helper-script
[ -d /usr/data/helper-script-cfs ] && \
tar -czf "$BACKUP/helper-script-cfs.tar.gz" \
    -C /usr/data helper-script-cfs
cd "$BACKUP"
sha256sum *.tar.gz > SHA256SUMS.txt
Copy the backup files off the printer using SFTP before proceeding.
Step 2 – Flash S11 V1.3.3.5 using Ingenic USB Cloner
This is the low-level recovery step.
  1. Turn the printer off and disconnect mains power.
  2. Access the motherboard and connect its internal USB recovery interface to your Windows PC.
  3. Launch Ingenic USB Cloner 2.5.18.
  4. Load CR4CU220812S11_1.3.3.5.ingenic.
  5. Leave the Cloner’s Lock Level at 2, as used in my successful recovery.
  6. Put the motherboard into USB boot/recovery mode and confirm Windows recognises it as USB Cloner Device.
  7. Click Start in Ingenic USB Cloner.
  8. After clicking Start, put the motherboard into USB boot/reset mode again. This triggers the Cloner to detect the device and begin flashing.
  9. Watch the progress in Ingenic USB Cloner and wait until the flash completes successfully.
Important: Simply clicking Start isn’t enough. You need to trigger USB boot/reset mode again after pressing Start for the flashing process to begin.
I initially encountered a Windows Code 52 driver-signature issue with the Ingenic USB driver, which needed resolving before the Cloner could communicate with the motherboard.
The .ingenic file didn’t visibly populate the image table as I expected, but the recovery completed successfully once the flashing process was triggered.
Once complete, disconnect the recovery USB connection and boot the printer normally.
Step 3 – Install S11 V1.3.3.46
With the printer running the recovered V1.3.3.5 firmware:
  1. Copy CR4CU220812S11_ota_img_V1.3.3.46.img to the root of a FAT32 USB drive.
  2. Insert the USB drive into the printer.
  3. Accept the firmware update.
  4. Wait for the update and reboot to finish.
I confirmed V1.3.3.46 was installed before proceeding.
Do not skip this step.
Step 4 – Install the S11 V1.3.3.50 bridge firmware
This is the critical part of the process.
Copy the following firmware to your USB drive:
Install it using the printer’s normal firmware update process.
Although the filename says S11, this firmware acts as a bridge to the newer S12/X2000E firmware branch.
The expected transition is:
S11 V2.3.5.34
       | Ingenic USB Cloner
       v
S11 V1.3.3.5
       | Normal USB firmware update
       v
S11 V1.3.3.46
       | Bridge firmware
       v
S11 V1.3.3.50
       | Firmware branch transition
       v
S12/X2000E V1.1.0.26.20251113
       | Final update
       v
S12/X2000E V1.1.0.27.20260703
The V1.1.0.26 version is part of the expected transitional sequence, not a separate image I manually flashed during my recovery.
Allow the printer to complete all update stages and reboots without interrupting power.
Step 5 – Install the final S12 firmware
The final firmware I used was:
This is the S12/X2000E firmware for the K1 Max CFS-C configuration.
During my recovery, the printer progressed into the V1.1.0.27 installation after the bridge process.
If your printer has already installed the correct final version, there’s no need to flash it again.
Otherwise, install the image using the normal USB firmware update process once the printer is running the S12/X2000E firmware environment.
Make sure you’re using firmware for CR4CU220812S12, not the different CR4SU200382C13 motherboard.
Step 6 – Verify the motherboard and firmware
After completing the recovery, SSH into the printer and run:
get_sn_mac.sh board
cat /etc/version
uname -a
My printer reported:
Motherboard:
CR4CU220812S12
Firmware:
K1MAX_V1.1.0.27.20260703
Kernel:
Linux 5.10.186
This confirmed that the printer was back on the correct S12 firmware branch.
Step 7 – Restore custom modifications carefully
If your printer was previously rooted or had Helper Script installed, don’t simply overwrite the new firmware’s configuration with your old backup.
The S12 firmware has significant differences, particularly in the CFS implementation.
For example, the older S11 firmware used:
[serial_485 serial485]
serial: /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
baud: 230400
The newer S12 CFS-C firmware instead uses:
[serial_can]
Reinstall your custom modifications individually and check compatibility with the new firmware.
I would recommend confirming normal printer operation before restoring anything.
Things that didn’t work
During troubleshooting, I tried extracting and installing the S12 firmware directly from the S11 firmware environment.
The S12 firmware uses a different OTA image format.
The older updater failed because it could not find the expected ota_config.in file.
I also examined the S12 firmware container and found separate RTOS, kernel, and root filesystem payloads, including their offsets and CRC32 checksums.
Although all three payloads passed CRC32 validation, manually writing them to flash would have bypassed the normal boot partition and update handling.
I didn’t use that approach.
The working solution was the Ingenic recovery followed by the .46 and .50 bridge updates.
Final notes
  • Confirm the physical motherboard revision before starting.
  • Back up your files before using Ingenic Cloner.
  • Use the exact recovery sequence rather than jumping straight to S12.
  • Don’t interrupt power during any firmware update.
  • Don’t restore an old S11 printer.cfg or box.cfg over the S12 versions.
  • Successfully installing S12 firmware does not necessarily mean your existing CFS USB adapter will work.
In my case, the printer successfully booted into:
K1MAX_V1.1.0.27.20260703 on CR4CU220812S12.
I am still investigating CFS USB compatibility after the firmware transition, so consider this a confirmed firmware recovery procedure rather than a confirmed fix for CFS detection.
Hopefully this saves someone else the amount of troubleshooting I went through.
You are the MAN! And just when I needed it.
I just picked up a K1 Max of FBM, I guess I now know why! When I went to the web backend there was no video feed from the camera and Z axis motor has a terrible coil whine. Figured config or drivers are probably corrupted or deleted by prev owner, so went about trying to get fresh firmware… Looked around the menu, checked for update to FW, no update. Guess I’ll try to update with a more manual method… Couldn’t update from usb drive… Huh, ok, got the right fw for the board, so that’s weird… Look at the settings again and correlated version on it to the available firmware list to see that the version is for an S11 board :man_facepalming:
Ok, I’m very technically inclined, I’ll flash the board with low level tools… no ingenic file for S12… Ugh
Found your post! Hooray!
Still have to go through the process though… Wish me luck!
Update: Just wanted to update and say it’s working! It only updated to 1.1.0.26 though and didn’t auto update to 1.1.0.27. After entering network info and telling it to check it said it was on latest :expressionless:
Awful coil whine is still present. I wonder if I can crack that z stepper open and secure the coils with superglue or something…
New Update: I think the network stack is messed up. I can connect to Wifi but I can’t access the backend. I did once… But it 404’d. I think it was before I did one of the updates in the chain. When I did the .50 update it seemed to have hung. The LCD’s backlight was on but there was nothing displayed. It was like that for 40+ minutes so I reset it and it turned on so I thought all was good. Perhaps not… The headache continues.
Oh, and I just found out creality revoked root access in these later firmwares :face_with_symbols_on_mouth:
Why do companies always forget their roots in pursuit of money…
Welp, guess I’ll go ahead and try this all over again :smiling_face_with_tear:
So 1.3.3.5 seems to have the backend and camera working, so I may stick with the 1.3 line since it has root access.
