Heads Up-Creality Print WEB Z movement INVERTED
I’m not sure if this is applicable to other printer models but:
When using the WEB Creality Print interface with my V3KE the Z movement in the “Control” section is BACKWARDS. -Z moves up and +Z moves down. I’ve checked it against the desktop app which works correctly (-z down / +z up ). Just a heads up for those who may be using this with large Z travels to maybe grease their rods or check other issues out. If you’re close to the bed and expect an upward movement of 100mm and get a down that would ruin your day. :grimacing:
