How do I change the home position on Falcon 2 pro? I want home to be back left so I can easily remove work.
Can’t find the option in Falcon Design Space but you can do it in Lightburn.
What software are you doing it in? If you’re talking about changing it short term in lightburn, it’s just a case of changing the machine origin in the device setting as above and is a software level solution, but it won’t auto home there when untethered
If you want it long term/firmware level, it’s a case of doing the above, then getting the position of where you want your home, sending $23 to set the home position and then g10 l2 p1 x y to set a new 0,0
It comes with added annoyances though, your x/y movement will be flipped, but I think you can correct for that
I’d get googling if you want a permanent solution of 0,0 being top right but you can easily half-arse it in lightburn’s device settings - asking on the lightburn forum will help - if you flip it though, creality’s dodgy software will probably throw a ■■■■fit if you try to use it though…. but if you’re doing this you want to be in Lightburn and as far away from falcon design studio as possible
Thanks that’s the info I needed!! Happy Holidays!!
