I replaced my nozzle and everything stopped working
today my printer was acting a little weird. I thought it was something wrong with the nozzle, so I replaced it with the spare that came with the printer. I put everything back together, turned it back on, and now no matter what I do I keep getting an error that says “spray head motherboard communication error” along with a QR code to a website that does not help at all. Suddenly the fans aren’t turning on, the light won’t even turn on, I can’t move the hotend or the bed using the buttons. The lights will turn on and the printer will connect to the Wi-Fi but that’s it. Every time I plug the nozzle bus cable back in, everything lights up, but nothing works. I’ve triple-checked all of the cables in the hotend and there’s nothing visually wrong. What did I do?
Sounds like the main cable on the printhead is loose or damaged. That’s the big on on the top at the back of the printer. I would unplug it and replug it.
Also, did you power down and unplug the printer before you plugged things in? It’s rare, but you can short something when working on the system while powered up.
