When doing an image engraving, can you pause the machine and change the speed and/or power in the middle of the program?
Support says NO. You can not pause the engraver and change any setting in the middle of a run.
Not possible with Falcon Design Space as it sends a completed ‘file’ to the device which cannot be modified mid-engraving.
Lightburn on the other hand sends commands in near real-time and a job can be paused, modified, then resumed. You may need to do some testing with this to master it, and as always be sure to check the Lightburn documentation for detailed guidance.
Thanks. That is what I thought. Right now, I can not afford Lightburn. I had to purchase that 500.00 Air Purifier.
