K1 Max Prints ABS but fails to feed filament after a few layers
So my K1 max has been printing abs great for years but suddenly started stopping feeding after a few layers. The extruder motor was very hot so I thought heat creep and slowed the printing speed, dropped the chamber temp. Still kept happening but after each failure I was able to extrude filament showing that the nozzle was not blocked. Then I realized that even though it was not feeding the extruder motor was rotating but no extruder clicking. I finally changed the nozzle and now OK but I don’t understand what was wrong with the original nozzle.
bilmar, the nozzles are wearable items, glad to here that you got years printing ABS on a single nozzles. but here is a list of what could have caused the issue
  1. Backpressure under flow: Manual extrusions push filament slowly, allowing molten ABS to slip past partial blockages or carbon buildup inside the melt zone. During high-speed printing, backpressure spikes significantly.
  2. Filament slipping vs. clicking: When backpressure exceeds the grip of the dual gears, the gears shave the ABS flat and slip smoothly over it without slipping back and clicking.
  3. Internal bore wear or carbonization: Micro-burrs or cooked filament lining the internal throat act like friction brakes once the filament softens near the melt zone.
Thanks, I think your option 1 was the cause the cause. A partially restricted nozzle allowing the filament to be extruded but eventually causing the extruder to overheat and then shave the filament and continue running. Thanks for your input.
