K1C extrudes 1 inch of material after a pause resume. NOT ooze?
Hi there,
I use the pause commanded in my Gcode when I’m changing colors on my K1C.
after I have changed out the color and I hit resume and temperature comes up to 220 and the bed rises, the hot end then extrudes about an inch (30mm) of filament. The hot end then moves from park position back to the project. The one inch (30mm) of filement then gets smeared on the project. It’s NOT oozing but appears to be an actual extrude.
is there a setting in the Creality slicing software that would prevent this from happening?
Thanks
Glen
Which version of the software are you using?
