K2 Owners: Possible Fix for Glow-in-the-Dark Filament Retraction Problems
I was having trouble with my K2 Pro retracting glow-in-the-dark filament through the CFS.
The CFS would attempt to retract the filament but couldn’t pull it back.
After troubleshooting, I discovered that disconnecting the black inline PTFE connector at the rear of the printer allowed the filament to retract normally.
I eliminated that connector and installed one continuous PTFE tube from the toolhead to the CFS splitter.
So far, the glow filament has been retracting successfully.
I’m sharing this in case anyone else is experiencing the same issue. It’s an early result, but the modification appears to have solved my problem. I got these results using the original white PTFE tubing, before installing the star-shaped replacement.
