K2 Plus First Layer Problems? Here’s the Real Fix (Build Plate + Z-Offset)
When I started printing with my new K2 Plus, the first layer was surprisingly unstable. Even with the exact same settings, the Z height felt inconsistent every time, leading to poor adhesion and over-extrusion.
After some investigation, I found the cause: the textured pattern on the stock build plate created uneven high and low spots. This made the nozzle contact point inconsistent during Z-axis calibration, resulting in Z-height variations.
I replaced the original build plate with the much flatter K2 Plus Epoxy Resin Build Plate, and the improvement was dramatic. First layer consistency and repeatability improved significantly.
I also realized that on the K2 Plus, you must adjust the Z-offset in the slicer settings. In my opinion, most first layer problems with stock filament and default print settings are caused by an incorrect Z-offset. Without adjustment, my first layers were clearly over-extruded. After setting the Z-offset to +0.04 mm, I finally got a perfect first layer.
Advice for new K2 Plus users:
If your first layer isn’t coming out well, don’t waste time tweaking lots of other print settings. Start with these two things first:
  1. Switch to a high-flatness build plate (like the Epoxy Resin one).
  2. Dial in the correct Z-offset.
    Doing these two steps made a huge difference for me and will probably solve the majority of first layer issues.
Thanks for sharing this — build plate flatness is definitely worth checking. I want to add a data point that might help others too.
I print almost exclusively PETG, and my first-layer/Z-offset inconsistency started exactly at firmware update V1.1.4.11 → V1.1.5.2. Before that update I never had to touch the Z-offset.
Since the update to V1.1.5.2, there seems to be a bug in the firmware that causes a shift in the leveling. What worked for me: manually dialing in the Z-offset in the slicer profile (a fixed value, saved per material) — once I did that, the first layer became reliable again, same build plate, same nozzle, nothing else changed.
I also tested downgrading back to V1.1.4.11 and can confirm the issue disappears there too without any Z-offset adjustment needed — so this does look like a firmware-related shift in the leveling starting with V1.1.5.2, not a hardware/plate issue.
For anyone chasing this: if it started right after a firmware update rather than being there since day one, try (a) setting a fixed Z-offset in your slicer profile as an immediate workaround, or (b) downgrading if you want to go back to the old behavior entirely.
Curious if you’re still on 1.1.5.2 (which I am currently using), and if you’ve had any updates on this issue (apart from saving the offset in your profile)? Thanks.
