has anyone had issues with the new FW 1.4.x.x and how did you resolve it. My k2 plus would do one print then crash on the next homing cycle. I had to roll back to 1.3xxx
I had some issues with the print head forgetting where it was and failing to home. That stopped prints from starting, but a power cycle immediately followed by a manual home command always fixes it for me.
I upgraded and got increasing numbers of system errors until it would not print - I tried following the wiki solutions - too hard, so I gave up and went back to 1.3.x.x
IMHO, nothing wrong with 1.3.x.x i didnât see a big improvement in 1.4.x.x. I thought about rolling back too, but decided the work around was easy enough for my needs.
what was the work around? Creality asked me factory default after the upgrade then try and i get the following error {âcodeâ:âkey60â, âmsgâ:âInternal error on command:BED_MESH_CALIBRATEâ, âvaluesâ: [âBED_MESH_CALIBRATEâ]}
Power cycle followed immediately by homing all axes in Fluidd as soon as it connects. Then everything would work normally for a few days.
thank you, i reverted to 1.1.3.X.. it works fine, i just didnt want to be on older FW
This is more for the Devâs than for us users:
I hit the problem again, but this time I was watching in Fluidd and got an interesting error:
â{âcodeâ: âkey353â, âmsgâ:âMCU âmcuâ shutdown: Stepper too far in past
This generally occurs when the micro-controller has been
requested to step at a rate higher than it is capable of
obtaining.â, âvaluesâ: }â
Just a guess, but since I donât get the error in Fluidd, but I do get it in Print, maybe Print is trying to do the initial calibration just a little too fast. OR, maybe I need to run a round of lubrication. ![]()
