K2 Plus motion issues
I recently purchased a K2 Plus second-hand. It had a broken screen and although that was easily replaced, it turns out there are deeper problems.
I’ve encountering some motion issues which began with the head banging against the sides as if it couldn’t tell it’s limits. After some testing, I found that the head can’t seem to move left/right only. Instead it stutters along a diagonal path. The gantry moves easily along the y-axis by hand without deviating, however along the x-axis, it tries to go diagonal.
Unfortuantely, I can’t get the machine past the setup due to it not being able to pass initial calibration. This has made most of the troubleshooting I’ve found in similar posts impossible. I have removed the back/side panels and inspected all idlers/tensioners/motors with nothing jumping out as being obviously wrong. Idlers appear to turn freely, with the belt running centered. Both motors turn as expected when moving the head around manually. I checked the gantry for alignment, but found no issue there. I have also tried loosening the belt tension one full turn on both sides manually to see if anything was binding.
I’ve considering replacing the x and/or y motor assemblies, the mainboard to see if it’s a signal issue, or possible the x-axis linear rail, but I want to avoid spending more than if I had just bought it new. Any assistance in finding the root of this issue is greatly appreciated.
Adding a video of the issue to show what I tried to describe above: https://youtu.be/MvZHDkYvDYc
