Printer: K2 Pro with CFS. Printer firmware 1.1.7.0 (hardware CR0CN200400C10), CFS firmware 1.5.3. Slicer: Creality Print 7.3.0.6157. Filament: Creality Soleyin Ultra PLA, Strawberry Milk, serial 5B02612000032A, barcode EUWW030-3301010602A (3301010602A), slot 1C.
What happened, in order:
- The spool came tangled from the factory. On the right-hand side of the photo the filament leaves the spool right next to the flange and runs underneath two windings, which pin it down. When the CFS pulled, it could not unwind and the filament snapped inside the CFS feed path, about a third of the way into the print. This is the second Soleyin spool with a crossed winding in two days; I did not photograph the first one, this one is in the photos.
- The printer kept printing with no filament. The runout sensor sits at the toolhead, so nothing reacted until the broken tail passed it. By then it had printed about two layers with nothing coming out of the nozzle. The CFS has a measuring wheel that knows the filament stopped moving; it did not stop the print.
- Then the slot was dead. Slot 1C went red. It would not extrude or retract, the screen would not let me heat or move anything because the job was paused, and once I pulled the broken piece out of the tube a fresh tip would not go into the slot, cut straight or at an angle.
- The only way out was switching the printer off for 10 seconds. After the restart the CFS rechecked the slots, 1C loaded normally and power-loss recovery offered to resume. No menu offered any of that.
- The resume printed hot. Recovery purged at 240 °C, as the load macro does, and the nozzle target stayed at 240 °C for several minutes after it went back to the part, before dropping to the 220 °C of the job. The inner seams strung in that window.
Result: the part is scrap (photos). The missing layers sit below the resume line and the infill above it is stringy.
The product is sold with AI failure detection and error recovery. None of this was detected: on an earlier failure I checked the printer logs and the AI check only ran for about six seconds at the start of the print. What saved the part from being worse was me, watching it.
What I would like from Creality:
- Quality control of the Soleyin winding, and a replacement for this spool.
- Stop the print when the CFS stops feeding, not when the tail reaches the toolhead sensor. The hardware to detect it is already in the CFS.
- A way to clear a red slot from the screen without a power cycle.
- Return to the print temperature right after the purge when resuming.
Photos attached.
