K2 Pro – CY2577 Y-Axis Failure, Diagonal Movement, Motor Tracking Error (Firmware 1.1.7.0)
Hi everyone,
I’m looking for advice from anyone who has experienced similar XY motor problems with the Creality K2 Pro.
My K2 Pro Combo has developed a serious Y-axis movement problem. I’ve spent quite a bit of time troubleshooting it, including analyzing the Klipper logs and performing servo motor calibration, but haven’t been able to resolve it.
I’m trying to determine whether this is a defective Y-axis motor/encoder, motor wiring issue, belt/pulley problem, or potentially a firmware bug.
How the problem started
The printer was previously working normally.
During a new ABS print, the printhead suddenly started moving incorrectly, travelling diagonally instead of following the programmed toolpath. It continued extruding, creating a large blob of ABS around the nozzle.
I restarted the printer and attempted another print. This time, it printed normally for several layers before stopping with a Y-axis error.
Since then, the printer has been unable to home correctly.
When attempting to home the Y-axis, the printhead moves only approximately 10–20 mm before stopping with an error.
Printer information
Printer: Creality K2 Pro Combo
Firmware: 1.1.7.0
Main error: CY2577
Additional errors:
key23,key789
I updated to firmware 1.1.7.0 when I first received the printer, so I have never tested it on an older firmware version.
Errors from Klipper
The logs repeatedly show:
{"code":"key789",
"msg":"error_code 位置跟踪误差过大",
"values":["y"]}
Translation: Y-axis position tracking error too large.
Approximately 0.8 seconds later:
{"code":"key23",
"msg":"Endstop y still triggered after retract",
"values":["y"]}
This sequence occurs repeatedly during failed Y-axis homing.
Motor diagnostics
I extracted the raw motor responses from Klipper.
Motor address 0x81 returns:
f7 81 0b 00 0c 00 00 00 00 00 00 00 00 fb
Motor address 0x82 returns:
f7 82 0b 03 0c 00 01 00 00 00 00 00 00 9c
Immediately afterward, Klipper reports key789 for the Y-axis.
Motor 0x82 also returns additional diagnostic data after the fault, so it isn’t completely disconnected.
Troubleshooting performed
1. Checked manual XY movement
With the printer powered off, the printhead moves freely along X and Y. I haven’t noticed any major binding or obstruction.
2. Checked endstop states
Running QUERY_ENDSTOPS returns:
x:open y:open z:open
3. Performed electrical-zero calibration
Using Creality’s servo motor calibration procedure in Fluidd, both XY motors reported success.
Motor 1:
Calibration successful
Maximum deviation: 5.4051°
Motor 2:
Maximum deviation: 1.9226°
However, attempting G28 X Y afterward still resulted in the same Y-axis position-tracking error.
4. Checked the belts and manual motor movement
This is my latest observation.
The K2 Pro has two CoreXY belts at different heights.
When I move the printhead diagonally in a way that primarily engages the upper belt, movement feels smooth and sounds normal.
However, when moving diagonally in the direction that primarily engages the lower belt, I hear a buzzing/resonating sound and can feel a slight notchy vibration through the printhead.
It feels almost like the motor is turning through small magnetic steps.
I’m unsure whether this is normal motor cogging or a sign of a bad motor bearing, pulley, or belt alignment.
Possible causes?
Based on the symptoms and logs, I’m considering:
Faulty Y-axis closed-loop motor or encoder.
Intermittent motor wiring or connector fault.
Motor bearing or pulley problem.
Belt alignment or tension issue.
Firmware 1.1.7.0 motor-control bug.
The sudden diagonal movement is particularly concerning because it suggests one of the CoreXY motors may have stopped following commanded movements correctly.
Questions
Has anyone experienced this exact combination of problems on a K2 Pro or K2 Plus?
Has anyone encountered CY2577 together with
key789(Y-axis position tracking error)? -
Has anyone experienced incorrect diagonal printhead movement before the printer started failing to home?
Does anyone know whether motor address
0x82corresponds to the motor driving the upper or lower CoreXY belt? -
Is a noticeable notchy vibration when manually moving one belt normal on these printers?
Has anyone experienced similar failures on firmware 1.1.7.0, or resolved them by downgrading?
If you had this issue, was the solution a replacement motor, cable, controller, or something else?
I’ve already exported the complete printer logs and contacted Creality regarding a possible warranty repair.
I’d especially appreciate hearing from anyone who has diagnosed a defective XY motor or experienced a similar problem.
Thanks in advance!
