K2 Pro Webcam Feed to Homeassistant or Frigate
Hello,
Has anyone managed to get the K2 Pro webcam working with NVRs such as Frigate or integrated into Home Assistant?
The camera is accessible via:
http://192.168.1.151:8000/
After investigating, it appears the camera is served using WebRTC rather than RTSP or MJPEG. The webpage posts a Base64-encoded SDP offer to:
/call/webrtc_local
and receives a Base64-encoded SDP answer in return.
I’ve confirmed:
  • Port 8000 serves an HTML page with a WebRTC player
  • RTSP port 554 is closed
  • RTMP port 1935 is closed
  • ffprobe http://<printer-ip>:8000/ does not detect a media stream
  • Adding webrtc:http://<printer-ip>:8000/call/webrtc_local to go2rtc in Frigate 0.17.0 results in:
mse: streams: sdp: syntax error at pos 1: "}"
Has anyone found:
  • An RTSP/MJPEG stream exposed by the printer?
  • A go2rtc configuration that works with the K2’s custom WebRTC signalling?
  • A method to bridge the K2 camera into Frigate or Home Assistant?
Any pointers would be greatly appreciated.
