lanes are not connected
Hi,
I’m very new in the 3D printing world and bought me the K1 Max. The printing result is quit different from the expected, because lots of the lanes are not connected to each other.
Here is how it looks like.
Could me tell anybody whats the reason of it? And how I could fix this?
Thanks Wooky
Hello @wooky …! :wave:
What temps and material are you using…?
If you search for discussions here on the forum for Z offset settings that might help you get a better first layer print to start… :smiley: :+1:
Also make sure the build plate is clean. :+1:
Hyper Series PLA
220° C Nozzle 50°C Bed
I use the standard setting of the device for hyper PLA
I have done the bed leveling descriped here and after the result is the same.
Everything works together when you are setting up these machines. If you leave something out like not adjusting the Z offset as I mentioned in my last post then your results will not change…
Clean the build plate with Iso Alcohol for best results.
Try adjusting the Z Offset also and see how it goes… :smiley:
