I’ve pulled out of the Sovol and went to the InfiMeck MX PRO with 8 toolheads
I’m just holding out that a K3Plus option will be available and will offer more tool heads that 4
Is Creality planning to keep the price range that is affordable for just casual users and Hobbyists like me?
Will you be selling your own specialized filament for cmyk?
I’ve changed my mind and now would hold off for the plus 8 nozzle system, if thats what Creality does.
I am still in for both, did pull out of the flashforge. I have 7 3D printers (5 are Creality) and will be adding 2 or 3 more over the next year. Probably will go for the K3, defiantly if it was the K3 Plus. When I can get an early printer at a good discount (or free) I will get it, pound away at it and design the hell out of mods for it. I also have 2 lasers ( one is a Creality) and am waiting to get my CNC and UV printers. I just retired and this is my hobby, it’s what I enjoy doing.
I got some eSun CMYW (CMYK is mislabeling) I hope that the K3 will be my first test of it but it looks like I might have one of the competitors first. I do have a U1 but the software for CMYK isn’t there yet.
I’m a bit late to the party, but neither CMYK nor CMYW are anywhere close to full-spectrum color, which makes either approach rather silly.
The only reason CMYK works on paper is because the paper provides 100% white, and everything is subtractive from there. If you try to do that with a filament printer, you can’t get any lighter than a medium grey.
CMYW also doesn’t work, because the CMY colors aren’t anywhere NEAR dark enough to blend with white and get anything much darker than pastels or a medium grey.
A full color gamut realistically requires five colors (CMYKW).
Yes, in theory, you could get a semi-passable approximation with a near-black blue-green, a near-black magenta, a near-black dark brown, and white, or with black plus near-white cyan, magenta, and yellow, but you won’t get very vibrant colors with either approach. You really need to be able to fully independently control both the brightness (YW axis) and the color (CMY axis) to get full spectrum, and there’s just no good way around that.
Four-color tool change printers just don’t make sense in an era when other companies are doing full-color printing. To get adequate contrast or color intensity, you would have to switch between black and white manually for every single layer, which is way too tedious for anyone in their right minds to do it. So this will never be capable of good full-color printing.
What makes that so obnoxious is that if they can build a four-tool-changer design, they’re no more than an hour of design effort away from building a 6-tool design that actually would be capable of full-color printing (CMYKW + breakaway/dissolvable support).
This printer just doesn’t make sense. It’s too close to being great from a design perspective, and yet hopelessly far away from a user perspective. They really need to take a step back and reevaluate the design, spending the extra few hours of design effort to turn it into a first-class color-mixing-capable printer with 6 tools, rather than a bottom-tier, fixed-colors-only printer with 4.
I don’t think that turning a four-tool machine into a six-tool machine would take an hour of design work. Two additional tools affect the dock space, frame size, electronics, power, preheating, sensors, calibration, firmware, slicer profiles, reliability testing and cost. A six-tool CMYKW plus support model would certainly be nice, but that does not make the four-tool design pointless or “bottom tier.”
Yeah, they use a tiny bit of power to keep the hotends at temperature. This is something like maybe 20 or 30 extra watts. Sure, it’s not zero, but it’s not a major redesign.
As for the frame size, Snapmaker can get four full toolheads into a frame that size. KliTek is just swapping hotends and tubes. Various pictures show that there should be room for way more than 4 (unless they accidentally leaked photos of a K3 Plus, in which case it’s even more sad that they would have only 4).
And the dock space should be limited almost exclusively by frame size. It’s not like you’re going to put other hardware in that space.
The electronic requirements should be basically zero, assuming they do all their communication over CANbus like most manufacturers do. It’s just a little more hardware squawking on a shared bus.
Calibration impact should be exactly zero, unless they are doing per-nozzle calibration, in which case it is changing the iterator in a for loop from 4 to 6 and taking half again longer. But they only need to calibrate nozzles that are actively being used, which should reduce that time significantly if you’re only printing with one or two nozzles. Heck, it might not even be useful to calibrate more than one, depending on tolerances, at least beyond doing a sanity check at a single position for height compensation. So minimal impact.
Firmware changes should also be very close to zero. It should literally be allocating 6 of some object and storing them in an array instead of 4, with different axis offsets for the hardware positions.
Slicer profiles should basically be changing a digit. If all nozzles are identical, then the only thing the slicer should care about is how many exist.
None of this stuff should be a huge burden unless they’re truly hitting the limits of the frame size, in which case they should rethink the frame size, because they’re about to get their lunch eaten by Sovol and Infimech.
The hard part is always going from one tool to two. Going from two to n is trivial, assuming your code and hardware is architected correctly, at least up to the physical size limits of the enclosure.
As for me, I saw what Snapmaker was offering, and I saw what Creality was offering, and despite the possibility that Snapmaker might do something bigger in a year or two, I just gave up and put money down on the new Sovol. If Creality announces an upcoming K3+ with 6+ nozzles before 9/3, I might reconsider, but otherwise, IMO, they’ve already missed the boat by being too conservative with their announcements. It’s not like saying “We’re going to release the K3 in [month] and the K3+ some time in 2027 with 6/7/8 nozzles” would be that hard a promise to keep. And if they’re worried about more nozzles in the K3+ Osborning their K3 sales, then maybe they should have started with the K3+ to begin with. Either way, it doesn’t make sense, speaking as a customer that they’re about to lose.
They will be making a larger versions, just like the K1 and K2 series. One of there engineers already said that. Q4
we should know for sure either at the Formnext Asia event or the event in Germany the beginning of sept.
I’m particularly interested in what happens inside the nozzle during a colour/material change. If each KliTek nozzle/hotend is already loaded with its own filament, how is the residual filament in the nozzle dealt with when switching to another colour, and how do you achieve virtually zero purge waste?
Also, when switching between 0.4 mm and 0.8 mm nozzles during the same print, how does the system compensate for the different flow rates/pressure to maintain consistent extrusion and avoid visible artefacts at the transition?
I’d also be very interested in participating in any K3/KliTek beta or early-user testing if Creality is looking for experienced K2 Plus users.
Hello , still not precision about the release date or the complete features ? I really need to know if there will be RJ45
I’m keeping my money for it so I’m really impatient
サポートを溶かした処理水が下水に直接流せればいいが、
産業廃棄物扱いで業者に依頼するなら一般人は止めた方が良いと思う。
他メーカーでは産業廃棄物扱いの為、購入を止めた。
処理水に関して説明が無いのが残念。
Will the Nozzles be able to have the CFS machines be able to go into them, allowing more filament per nozzle?
@usagi said “It would be nice if the treated water dissolved in the support could be flowed directly into the sewage,
I think that it is better for ordinary people to stop it if you ask a contractor for industrial waste treatment.
Other manufacturers stopped purchasing in order to treat industrial waste.
It is a pity that there is no explanation about the treated water.”
**Are you talking about water soluble filament waste?
こんにちは。
そうです。
水溶性フィラメントを溶かした水の処理方法が書かれていない事です。
ある人は外に置いて蒸発させればいいと言いますが、問題は無いのでしょうか?
私が知っている人は産業廃棄物処理業者に依頼してます。
メーカーからそのように処理を指示されていると言っています。
日本ではそれがルールとなっています。
Crealityは処理方法が書かれていません。
それがメーカーとして????です。
