Newbie having trouble printing
I cannot seem to get my brand new s 31 pro to print, it drags and not sticking to bed
May have to lower your z offset down. Have you gone through the bed levelling process of each corner with a bit of paper then adjusted your offset correctly before running the auto bed levelling sequence
Hello @grg595 and Welcome to the Creality Forum…! :wave:Creality
What @amberhelios said…
Clean the bed with ISO (alcohol) and what temps are you using for the nozzle and bed…?
Even with auto leveling you still have to check the Z offset to make sure the nozzle is the correct distance.
I usually print a flat 100 x 100 mm thin sheet and watch how the filament lays down. On some machines and slicers you can change the Z offset while the machine is printing…
Make small changes… A minus # means the nozzle is that much closer to the bed. For example -.10 moves the nozzle .10 closer to the bed.
using 200 and 60 temps,
That’s pretty close. I’d bump the nozzle to 220°C and see how that works…
Do some research online about Z offset and get that set.
Also make sure the filament is dry.
Thanks, got it working OK now at 210, and adjusted z offset.
Good to hear…!! :+1: Glad we were able to help…
Have fun…!
