Defective Creality HyperX Polycarbonate, I have 40Kg of Sealed HyperX PC that snaps in your hands and every attempt fails.
Starting a google folder to document every attempt.
https://drive.google.com/drive/folders/1b6Lm8m7e-kDvmItOQjQpbxT5Xyk184CS?usp=sharing
todays fails are in “10.29.26 breaks”
Lets start off with the equipment i have so you can understand the testing.
- Custom designed convection oven that circulates air, and also has a dry air input into the oven so that it can displace the wet air that contains the released water. this oven has been tested up to 450C or like 900F. it circulates the air and has a dry air input.
- multiple vacuum chambers from 10” to 20” made by BVV and 2 different vacuum pumps, the 2nd is a varian lab pump. i usually drop my filament into these and ensure it gets below 400 micron, that ensures that zero water is left in the spools after the drying, so 12-24hrs oven then 4-12 or 24hours in a vacuum chamber below 400 micron.
- 3 different filament dryiers that are solely for keeping the filament dry while printing. a creality (max 65C) , a sunlu (max 70C) , a geetech that does about 86C. these are solely for keeping the filament dry as they print.
- i have 100kg of activated alumina pellets/balls.
- i have 10kg of molecular sieves that i use for the high quality filaments or if needed.
- plenty of sealed plastic spool containers for temporarily holding filament. but before use its always dried again.
- i have NIDEC FG-3003 rated for 10 N / 1 kgf and a NIDEC FG-3009 rated for 100 kgf / 1000 N
- i have 2 highly modified or high end custom printers solely for high temp. ill just say the stats for them. the industrial is a duet custom system that runs a 200C bed thats a solid aluminium 25mm thick bed at 500mm x 500mm, it has 750mm of z travel.
it runs a 135C chamber max, and a 500C idex nozzles. its a cartesian template so its extremely precise. and is fully watercooled.
the other is a medium temp, its a bed slinger for high precision on the belts, i dont want to runing it above 70C because i know the bearings and some plastics on the connectors are not rated above 80C, so a chamber thats 70C and nozzle to 300C and bed to 120C. all motors and extruders are watercooled and also the heatbreak is watercooled.
my last print with the hyperx pc came out perfect but then the next print on spool #7 kept snapping before it could even reach the nozzle, spool 7 / 40 was dried at 100C for 16 hours then placed in a vacuum chamber for like 6 more hours and showed about 350micron i believe, i lost track of the exact time. but the outside loops, or rather 0.3kg of the start of the spool printed with zero issues and didnt break.
after completing the print i sealed the container it was in. then 2 days later i needed the next PC prints but it would now reach the brittle inside of the spool with stressed inner loops i believe, i got about 0.1kg out of it then its started snapping on every print attempt. 4 failed prints that completed about 20g of 90g of the model.
literally snaps prior to the extruder, this is a quick kink test after hours of fails its my 3rd kink test that night because the best kink test that showed the durable section then weak section, the camera stopped recording after 30sec so it was lost.
these are on the 10.29.26 folder of all the print fails and filament snapping and shattering in the extruder.
i am going to try to anneal spool 7 at 110C for 2-3 hours. then drop to 100C 45min then 90C 45min then 80C then a slow ramp to 50C then place in a container to room temp. then check another kink test and see if it can print anything.
i haven’t tried annealing a spool close to tg, so i dont know if it will help, but its supposed to.
here is the filament i am talking about
I have dried from:
70C @ 12 hours
80C @ 12 hours
80C @ 24 hours
90C @ 12 hours
90C @ 24 hours
100C @ 12 hours
100C @ 18 hours
110C @ 16 hours
90C @ 6 hours then vacuum chamber 4 hours @ less than 500
90C @ 10 hours then vacuum chamber 6 hours @ less than 500
100C @ 6 hours then vacuum chamber 6 hours @ less than 500
100C @ 18 hours then vacuum chamber 6 hours @ less than 500
110C @ 12 hours then vacuum chamber 6 hours @ less than 500
100C 12h & annealing 114C 3 hours with 5C stepdown per 30-45min to 80C
100C 12h & annealing 120C 2.5 hours with 5C stepdown per 30-45min to 80C
100C 12h & annealing 130C 2.5 hours with 130C → 120C → 110C → 90C stepdown every 30-45min
Even with the 130C annealing, the Creality Hyper PC cracks in the prusa nextruder in random sections of the same spool, from the 7 spools i have tested some will not crack the filament at the start of the spool and get your hopes up!!! But they all contain random sections that will just start shattering and cracking as it enters the nextruder gear. So you will get excited and then your prints will randomly stop after 10g or 20g or 50g.
I have gotten lucky sometimes opening a fresh spool, drying 100C 12hours and vacuum chamber 6 hours, because i believe the start of the spools have less curl and fewer internal stresses on the loops.
I don’t believe Extrusion Tension on the filament is a factor because the crack is always located directly at the nextruder gear.
I feel that Creality is really trying hard to deny replacing the defective batch, because they keep saying they only want to replace 25%, even though they couldnt provide a plan for testing, never explained the batch numbers on each set of packages, so we could estimate the number of bad spools with testing. Tried to say it was not dried, then said it was too dry and that water allows it to be more flexible.
Said it was environmental conditions,
Said it was expired,
Prusa and Aon both lied about their printers so i had to re-design them, gut the motion systems and run duet and design quite a bit to get a printer that perfectly control the chamber and thermal zones and drift. It took a little time. So once those printers were fully qualified to run polycarbonate perfectly without warping, i ended up verifying more spools in the creality order 7/40kg so far 7 of 40 are tested and 7 of 40 are defective.
Creality how exactly am i supposed to test 40kg of sealed polycarbonate effectively?
Your effectively pushing all the work of your defective filament onto me.
SO here we are going to post all the testing for the order of 40kg and your actions taken for a a large order that was placed to run on an industrial machine thats rated for 120C chamber, 200C bed and 500C nozzles.
If a custom designed and majorly optimized system cant run your filament without major issues, how can other people trust your polycarbonate filament?
Here is another video of the fact that the spools have both durable and completely unusable brittle sections.
drive.google.com
Google Drive file.
and that spool cracking in the extruder
drive.google.com
Google Drive file.
there are now multiple videos of this exact behavior seen on every spool of this batch.
creality what is the batch number and how many spools carry the same batch number?
Definitely difficult, because Creality again cites they don’t want to cover the filament, and they don’t cite a referenceable rule. where do they cite that they wont cover the 12 month warranty they put right on the filament page for unopened filament and i need working PC filament not a refund.
I fully understand how you feel.
Due to policy restrictions, the time elapsed since your order was placed far exceeds the permitted replacement period. Your request for a full replacement falls outside the scope of our current policy. I notice that your order was placed via the eBay platform; I suggest that you first consult with eBay’s customer service team regarding a replacement. They are authorized to provide priority assistance and may be able to escalate your case to seek an exceptional solution on your behalf.
I hope your issue can be resolved.
This was purchased from the
creality-official-store
and the page specifically cites
12 month warranty. they talk about printers and printer consumables, but filament is not a printer consumable it is the material being processed. You would not call or categorize the metal you tig weld a consumable it is the material you are working with, turning it into the processed goods. It is just not called a consumable, nozzles or tungsten sticks are consumables
Internal policy cannot override an advertised warranty unless it is specifically bait and switched with a “gotcha” in the small hidden details warranty page. However it is not present in their cited warranty page, the 2025 version or the 2026 version. they dont talk about unopened sealed defective filament from the same batch numbers
Because it was a large order they dont what to replace it, but its a large order for a large printer.
10.31.1pm
“20261031_130456 Spool 4 130C anneal extruder cracking filament 2 main.mp4” nextruder cracking seen at 1:00
spools 4 and 6 lightly welded to there spools so it was good for an annealing test but made it a poor test for using it. but it does effectively verify that annealing or drying is not repairing the defective PC that shatters in the nextruder, i have also loosened the pressure on the nextruder way more than the usual to verify its not a pressure setting.
11.1.26
For spool 8,
we did 110C drying, with air pump on into the oven for 7.5hours. no rain outside so it should be dry. texas 78247 @ 11.1.26 @ about 1pm
vacuum chamber for about 10 hours.
I will get a print going and post the settings but my problem is the cracking in the nextruder gear before it reaches the nozzle, so that’s not exactly part of the printer settings.
I also expect the start of the spool to potentially not be as tempermental.
I will run a 70C chamber, and run spool 8 at 86C in a dryer as it prints.
Dont forget that this material has ESC, or stress cracking too.
i will continue on the
https://www.reddit.com/r/3Dprinting/comments/1xkyvi7/polycarbonate_hyper_pc_spools_have_random/
because it allows me to properly update the progress and testing without deleting or preventing adding the updates
My Desk is Warped not the model
Caliper Flat Edge
zero warping
Print model Left Toolhead
These prints have zero bed warping as you can see from the caliper flat edge.
Print model Left Toolhead was printing at 40mm/s and was a 12 solid layer setting, with 0.2mm layer height and 6 perimeters on a 0.6mm nozzle. At 255 temp, 110C bed . Possibly too warm but then why does the right toolhead still have the same issue when printed at 245?
However the left toolhead has wavy edges that are 58.62-58.20 thats a 0.42mm screw up…
A Change that big on a direct-drive nextruder… That doesn’t make sense as an extruder or motion system error. even in the worst case when running 40mm/s if the extruder or PID heat input was causing an error that couldn’t be detected.
I really suspect the filament is causing this because we definitely measured that the filament is not consistent or homogeneous on ductility, and if it has a variation in TG or melting point its extruder pressure is going to vary and cause this exact behavior when there is an inner/outer perimeter print order and a 6 perimeter scheme.
Or it could be that the filament is cracking in these sections and causing the system to drop pressure on those layers, but for it to be wavy you need a smooth change not an abrupt change. That abrupt change should not be observable as a progressive wave. Its just less likely and more likely that the material is not homogeneous in its molecular behavior.
This wavy behavior is observed on all the models that were placed on the bed, and also all the models that occurred on the 2nd plate (Print model Right Toolhead) contained this as well even though it was a manual nozzle temp set to 245C at layer 2.
Though we can see that the same settings on the “Print model Right Toolhead Lock single model plate” did not have this wavy effect and it is only a 240C print temp change everything else was identical to the “Print model Right Toolhead“ job.
Ii will migrate the profile settings from prusaslicer 2.9.5 to orcaslicer next and see if the inner/outter/inner perimeter print order yields different and repeatable behavior.
This is the same settings again but now at 240C, but only 1 small model on the plate. But we cant observe the wavy walls, And if material contraction was causing this, shouldn’t we see issues with the flatness on the bottom surface or curving on other areas. Heck look at the lower part of the shroud on Print model Left Toolhead wavy but theres really not enough cross-section to cause a huge contraction and by thermal expansion laws a small part will contract less that a large part.
