New to 3D printing, but not technology.
Bought a used ender 3, early version, so I
- upgraded firmware
- replaced broken extrusion mechanism with OEM upgrade
- Added 2nd Z axis drive with OEM upgrade
- Replaced leveling springs
- new OEM PLA
- Checked bed for warpage, none
- Check bed level with feeler gauge, .2 & .17 mm
- cleaned surface with dish soap and only handle by the edges
- tried glue stick and hairspray
- nozzle temp 200, bed temp 50, I have tried +/- 10 on both of those numbers
Everything I try to print fails to stick on the first pass. Most of the time the 2 vertical passes will stick, but not always, and as soon as it moves side to side, it breaks loose. This older model does not have the auto level feature, and the Z offset seems to set itself, I can’t dial in a number as I have seen some do on youtube.
I was wondering with the new stepper added to Z, if I need to check the steps/mm rate? It seems to raise and lower equally, and the X axis bar is level every time I measure it when it stops.
Pretty much out of ideas.
Thanks
