Replaced print head and printer will not continue to feed filament print head clogs up and after cleaning will print for a few min then stops feeding machine
printer is only 6 months old It is KE series
What filament are you trying to print? Is the retraction distance too high? Is the nozzle temperature too low? Have you checked inside the extruder for extraneous bits of filament? Is extruder tensioned correctly.
I’m having the same issue. I already tried everything!
same printer!
