Hi, I’m having a problem where I can’t get the internal contours of the Eclipsion RC plane model to print. Vase mode is enabled, but the slicer is omitting the reinforcement structure. I have the latest version installed.
Thanks
Thanks
Vase mode only prints 1 outside wall after the vase. The reinforcement structure would only be printed if the model is designed so the slicer thinks that is part of the outside. I have seen models where there is a small gap, which forces the slicer to go inside and back out again, creating the fused internal stucture, by having the walls close together. This technique requires you to know the minimum gaps and wall thickness needed for the slicer not to ignore them.
