Slicer is not working properly HELP!
My slicer is all of a sudden not doing as well as it has. I have tried uninstalling and reinstalling, light mode, I have downgraded to V5 and still does not cut correctly. As you can see from the pics The marker protruding is not there. it has the cup and the letters but cuts off part of the marker. Has anyone seen this before and do you know the fix.
@3Doober welcome to the forum :slightly_smiling_face: Can you download and try to slice this exact model in Orca Slicer?
Let me know if it slices correctly or if the issue still persists. This will allow us to narrow down on whether the issue is related to a software bug in Creality Print or if it’s caused by the model itself having some issue.
Warmest Regards
Alawhie
Hello !
Have you tried to use the “repair” function ?
When the slicer doesn’t see a surface/volume, it generally is because there is a modeling issue
Change walls to arachne and turn on “detect thin walls”. Looks like they are just too thin
can you share the STL or AMF of the model to try it on my side.
Hey Alawhie. This slices just fine in Orca. Only seeing the issue in Creality print
Hey Alex. I have tried the repair function but it did not help. Thanks for the suggestion
Hey Lori
You are my Hero. This was the setting that worked. I just successfully printed this. Thanks for the help on my issue.
Glad I could help :slight_smile:
