So my fillmant moves everytime on the bed
i tried every bed temp
like 65 my normal one i ussaly go to 75 that still makes it move
any way to fix it??
Things to check:
Make sure the bed is level.
The nozzle distance to the bed might be to far away.
The filament can’t be squished down on the bed to stick like it should.
Check those two things. :+1:
I would also recommend using the guidelines on the filament spool… I cant see the entire roll as the sides are missing in the picture but it does look like the labels specifies a bed temp no hotter than 60c so you should not be using temps such as 65 or 75c.
I re did the calibration and it fixed it
