Sparkx i7 going offline
New to 3d printing and have had a Sparkx i7 for a couple of weeks - no issues to assemble, latest firmware downloade, print etc - connected to a Win 11 PC
BUT I now have an issue with the printer going offline which I can’t work out why.
Start the Creality s/w - print something (no problem) - leaving the printer on an after a while the printer goes offline - and I can find no way to get it back online.
A search did suggest adding the machine’s IP address to my router (BT Business Broadband) and “always use this IP address” - did that yesterday with an IP address ending 197 - today machine printed and then went offline, and showed IP address ending 198 when I rebooted the printer.
I’m guessing this is something to do with the offline issue? - is there a setting/fix OR is it possible to connect printer and PC by cable?
Thanks in advance for guidance
I think I may have the solution - to avoid the offline issue the Sparkx needs a “static IP address” (in other words always the same one) - you normally set that up in your broadband router for the specific device (in my case the only device running at 2.4GHz)
BUT when I set up an IP address on the router the printer ignored it - I then used the IP address that the printer was showing and set my router to that, with “always use” set to Yes. So far that seems to have worked . . . . (I may be back later with a different story!!)
Habe das Problem gefunden,
Du musst oder kannst ihn nur noch über die Windows App reality print bedienen musst aber ganz oben rechts da wo auch das Schließen Fenster ist von dem Beta Modus in den expertenmodus wechseln und dort hast du dann wieder Zugriff und kannst auch wieder Druck starten aber nur noch von da über App geht weiterhin nicht
Bei mir seit heute das gleiche Problem , seitdem Ich die Creality Print auf win 11 installiert habe , wird er mir in der App nur noch als offline angezeigt Zurücksetzen des Protokolls erfolglos obwohl Drucker hochfährt . Router neu gestartet auch erfolglos versuche jetzt noch mal Zugriff über die Windows 11 App und da es mit ihr zu tuhen hat. Versuche jetzt den Drucker mal über LAN ans Netzwerk anzuschließen
5 days on and quite a bit of printing - it’s not dropped to offline. The way the static IP was set up seems to have worked.
Hello! Could you please tell me how to change the IP address on my Wi-Fi router so that my printer doesn't show up as offline?
You’ll need to go into the management part of your router and find the wifi connection for the Sparkx (if it’s like mine it’s the only one at 2.4GHz) - set it to “Static IP” and make a note of the series of numbers - probably something like 192.168.1.199 - and then on the screen on the Sparkx set the same numbers for the IP address. Reboot the computer and the Printer. That may or may not work - if it doesn’t then do it the other way round taking the numbers from the printer screen (the last figure will be different) and entering those in the wifi connection on the router and save. Reboot as before.
It was the second option that appears to have worked for me. [My router is a UK BT Business Broadband Hub]
